Aller au contenu principal
B-Flat Clarinet Key Pad Replacement
Ce dont vous avez besoin
  1. B-Flat Clarinet Key Pad Replacement, Key Pad: étape 1, image 1 de 1
    • Disassemble the clarinet until you are handling only the joint containing the missing or damaged pad.
    • If the pad is missing completely, skip to step 3.
  2. B-Flat Clarinet Key Pad Replacement: étape 2, image 1 de 1
    • Remove the damaged pad by inserting the screwdriver under the pad and peeling it off the key.
  3. B-Flat Clarinet Key Pad Replacement: étape 3, image 1 de 1
    • Squeeze a dot of super glue into the empty key.
    • Take care to not overfill the key or glue will ooze out and potentially bind the key to the instrument.
  4. B-Flat Clarinet Key Pad Replacement: étape 4, image 1 de 1
    • Quickly insert the new pad into the key, taking care not to smear the glue.
  5. B-Flat Clarinet Key Pad Replacement: étape 5, image 1 de 1
    • Using the screwdriver, press the pad down to secure it to the key
    • Hold the pad for 5 seconds to let the glue harden
  6. B-Flat Clarinet Key Pad Replacement: étape 6, image 1 de 1
    • Place a small piece of paper between the key and the instrument to avoid residual glue binding the key to the instrument
    • Let the instrument sit out for a few minutes to let the glue fully dry
Ligne d'arrivée
Rachel Strobel
Membre depuis le 10/04/17
101 Réputation
1 tutoriel rédigé
Équipe
Michigan Tech, Team S3-G7, Galliah Fall 2017 Membre de l'équipe Michigan Tech, Team S3-G7, Galliah Fall 2017
MTU-GALLIAH-F17S3G7
1 membre
1 tutoriel rédigé
Un commentaire
From my point of view it would be better to disassemble the key and clean it before gluing a new pad. The best glue in these cases is shellac
Roberto Ottaviani - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,364
