Introduction
Common issues that involve the charging base battery is when it cannot hold a charge while unplugged. It is important to know the difference between replacing the charging base's battery and speaker's battery. The charging base battery should be replaced for the reason listed above while the speaker's battery should only be replaced if the speaker will not power on, even when plugged into the Micro USB charger and to an AC adapter that is plugged into the wall.
Ce dont vous avez besoin
Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
