Aller au contenu principal
BLU Advance 4.0 Rear Case Disassembly
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: étape 1, image 1 de 2 BLU Advance 4.0 Rear Case Disassembly, Removing the back cover: étape 1, image 2 de 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
  2. BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: étape 2, image 1 de 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: étape 2, image 2 de 3 BLU Advance 4.0 Rear Case Disassembly, Revealing the motherboard: étape 2, image 3 de 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
  3. BLU Advance 4.0 Rear Case Disassembly, Separating motherboard from screen: étape 3, image 1 de 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
David Okide
Membre depuis le 10/19/14
14 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G2
3 membres
6 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 7
Total : 8,440
