Aller au contenu principal
BLU Dash JR D140 Digitizer Replacement
Ce dont vous avez besoin
  1. BLU Dash JR D140 Digitizer Replacement, Battery: étape 1, image 1 de 1
    • Turn off the phone first. Press the power button continuously for 2-3 seconds to shut down the phone.
    • Using a plastic opening tool, pry open the back cover from the slit on the bottom right corner of the phone.
  2. BLU Dash JR D140 Digitizer Replacement: étape 2, image 1 de 1
    • Using a plastic opening tool or finger, pull out the battery.
  3. BLU Dash JR D140 Digitizer Replacement, Digitizer: étape 3, image 1 de 1
    • Remove the four 4.0mm Phillips #1 screws.
  4. BLU Dash JR D140 Digitizer Replacement: étape 4, image 1 de 1
    • Starting from a corner, separate the panel from the frame using the plastic opening tool.
    • The volume button will pop out.
  5. BLU Dash JR D140 Digitizer Replacement: étape 5, image 1 de 1
    • Unscrew the 3.6mm Phillips #0 screw from the motherboard.
  6. BLU Dash JR D140 Digitizer Replacement: étape 6, image 1 de 1
    • Using a spudger, lift the black ZIF connector at the top left corner of the phone.
  7. BLU Dash JR D140 Digitizer Replacement: étape 7, image 1 de 1
    • Pull the ribbon cable out of the ZIF connector.
  8. BLU Dash JR D140 Digitizer Replacement: étape 8, image 1 de 1
    • When the ribbon cable is removed from the ZIF connector, peel off the power, sticky button using a plastic opening tool.
  9. BLU Dash JR D140 Digitizer Replacement: étape 9, image 1 de 1
    • Peel off the volume sticky button.
  10. BLU Dash JR D140 Digitizer Replacement: étape 10, image 1 de 2 BLU Dash JR D140 Digitizer Replacement: étape 10, image 2 de 2
    • Separate the screen cover from the motherboard using the plastic opening tool. And don't forget that your phone can mess up if u separate the motherboard from the screen cover
    • Make sure that the LCD screen stays attached to the motherboard while doing this.
5 autres ont terminé cette réparation.
Nathanael
Membre depuis le 07/23/15
233 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,220
