Aller au contenu principal
BLU Dash Music 4.0 Headphone Jack Replacement
Ce dont vous avez besoin
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: étape 1, image 1 de 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: étape 2, image 1 de 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: étape 3, image 1 de 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: étape 3, image 2 de 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: étape 4, image 1 de 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: étape 4, image 2 de 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: étape 5, image 1 de 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: étape 5, image 2 de 2
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: étape 6, image 1 de 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: étape 6, image 2 de 2
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: étape 7, image 1 de 1
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
Lioma Terrero Soto
Membre depuis le 10/16/14
525 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Membre de l'équipe UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 401
