Aller au contenu principal
BLU Energy X Battery Replacement
Ce dont vous avez besoin
  1. BLU Energy X Battery Replacement, Battery: étape 1, image 1 de 3 BLU Energy X Battery Replacement, Battery: étape 1, image 2 de 3 BLU Energy X Battery Replacement, Battery: étape 1, image 3 de 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Battery Replacement: étape 2, image 1 de 2 BLU Energy X Battery Replacement: étape 2, image 2 de 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Battery Replacement: étape 3, image 1 de 3 BLU Energy X Battery Replacement: étape 3, image 2 de 3 BLU Energy X Battery Replacement: étape 3, image 3 de 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
4 autres ont terminé cette réparation.
Sishun Wang
Membre depuis le 02/08/16
630 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 12-2, Eyestone Spring 2016 Membre de l'équipe USF Tampa, Team 12-2, Eyestone Spring 2016
USFT-EYESTONE-S16S12G2
3 membres
5 tutoriels rédigés
2 commentaires
Hi. I my short Band Aid q makes connection between the battery and cell .. q do ? They are fixable ?
tamara diale - Réponse
directions were pretty straightforward... mine had a tiny sticker w/ the "B" in BLU printed, covering the screw on the upper left corner that needed removal (warranty?). otherwise, simple replacement...thanks!
joe doe (ch555x) - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 1,927
