Aller au contenu principal
BLU Energy X Motherboard Replacement
Ce dont vous avez besoin
  1. BLU Energy X Motherboard Replacement, Battery: étape 1, image 1 de 3 BLU Energy X Motherboard Replacement, Battery: étape 1, image 2 de 3 BLU Energy X Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Remove the back case using plastic opening tool.
  2. BLU Energy X Motherboard Replacement: étape 2, image 1 de 2 BLU Energy X Motherboard Replacement: étape 2, image 2 de 2
    • Remove the seven 4mm Phillips #000 screws.
    • Remove the top plate.
  3. BLU Energy X Motherboard Replacement: étape 3, image 1 de 3 BLU Energy X Motherboard Replacement: étape 3, image 2 de 3 BLU Energy X Motherboard Replacement: étape 3, image 3 de 3
    • Detach the battery from the mother board using a plastic opening tool.
    • Use a plastic spudger to remove battery.
  4. BLU Energy X Motherboard Replacement, Motherboard: étape 4, image 1 de 2 BLU Energy X Motherboard Replacement, Motherboard: étape 4, image 2 de 2
    • Use the flat end of a spudger to flip up the black retaining flap on the ZIF connector.
  5. BLU Energy X Motherboard Replacement: étape 5, image 1 de 2 BLU Energy X Motherboard Replacement: étape 5, image 2 de 2
    • Gently pull the ribbon cable free of the ZIF connector.
  6. BLU Energy X Motherboard Replacement: étape 6, image 1 de 2 BLU Energy X Motherboard Replacement: étape 6, image 2 de 2
    • Gently peel up the antenna.
    • This is secured with some light adhesive, so some force may be required.
  7. BLU Energy X Motherboard Replacement: étape 7, image 1 de 3 BLU Energy X Motherboard Replacement: étape 7, image 2 de 3 BLU Energy X Motherboard Replacement: étape 7, image 3 de 3
    • Gently rotate the motherboard up so that the front-facing camera is pointed towards you.
    • Use the pointed end of a spudger to disconnect the antenna cable and the ribbon cable.
  8. BLU Energy X Motherboard Replacement: étape 8, image 1 de 2 BLU Energy X Motherboard Replacement: étape 8, image 2 de 2
    • Lift the motherboard up and out of the device.
Geoff Wacker
Membre depuis le 09/30/13
88 931 Réputation
89 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 400
