Aller au contenu principal
BLU Energy X Plus Screen Replacement
Ce dont vous avez besoin
  1. BLU Energy X Plus Screen Replacement, Battery: étape 1, image 1 de 2 BLU Energy X Plus Screen Replacement, Battery: étape 1, image 2 de 2
    • Before disassembling your BLU Energy X Plus, make sure it is powered off.
    • Flip your device to the left side facing up and take out the SD card tray using the SIM card eject tool. You will insert the tool in at an angle and lift the tray up.
  2. BLU Energy X Plus Screen Replacement: étape 2, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 2, image 2 de 2
    • Flip your device to the right side facing up and use the SIM card eject tool to remove the SIM card by pushing the tool in the hole. You will feel a button click and the tray should slide out 2mm. You will then use your fingers to pull the tray out.
  3. BLU Energy X Plus Screen Replacement: étape 3, image 1 de 1
    • Flip your device over so your back cover is facing up.
  4. BLU Energy X Plus Screen Replacement: étape 4, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 4, image 2 de 2
    • Take the blue plastic opening tool and insert it in-between the back of the phone and the chrome trim. Go all the way around the device slowly to take the back cover off.
  5. BLU Energy X Plus Screen Replacement: étape 5, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 5, image 2 de 2
    • Remove the six silver screws from the cover plate, and one black screw from the top.
    • Use the screwdriver head J000 to remove all the screws.
    • Six silver screws, all 1.5mm in length.
    • One black screw, 1mm in length.
  6. BLU Energy X Plus Screen Replacement: étape 6, image 1 de 1
    • After all the screws are out, lift the protective metal cover off of the phone. Lift from the bottom of the cover.
  7. BLU Energy X Plus Screen Replacement: étape 7, image 1 de 1
    • Use the small blue plastic opening tool to lift the contact attached to the battery from the motherboard of the phone.
  8. BLU Energy X Plus Screen Replacement: étape 8, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 8, image 2 de 2
    • Use the small blue plastic opening tool to lift the battery from the bottom with little force because the battery will be glued in.
    • Then, use your hand to remove the battery completely.
  9. BLU Energy X Plus Screen Replacement, Camera: étape 9, image 1 de 2 BLU Energy X Plus Screen Replacement, Camera: étape 9, image 2 de 2
    • Disconnect the contact patch using the small blue plastic opening tool.
  10. BLU Energy X Plus Screen Replacement: étape 10, image 1 de 1
    • Loosen the camera from the glue using the small blue plastic opening tool.
  11. BLU Energy X Plus Screen Replacement: étape 11, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 11, image 2 de 2
    • After loosening the glue from the bottom of the camera, lift the camera out of the phone.
  12. BLU Energy X Plus Screen Replacement, MotherBoard: étape 12, image 1 de 1
    • Remove the black screw using a screwdriver head J000.
  13. BLU Energy X Plus Screen Replacement: étape 13, image 1 de 1
    • Lift the black tab on the zero insert force connector on the lower left side of the motherboard using a small blue plastic opening tool.
  14. BLU Energy X Plus Screen Replacement: étape 14, image 1 de 1
    • Lift the black tab on the zero insert force connector on the lower right side of the motherboard using a small blue plastic opening tool.
  15. BLU Energy X Plus Screen Replacement: étape 15, image 1 de 1
    • Remove the yellow tape that's on the black panel using your fingers.
  16. BLU Energy X Plus Screen Replacement: étape 16, image 1 de 1
    • Lift the black tab on the zero insert force connector on the top left side of the motherboard using a small blue plastic opening tool.
  17. BLU Energy X Plus Screen Replacement: étape 17, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 17, image 2 de 2
    Outil utilisé dans cette étape :
    • Use a fine nose pair of tweezers to pull the ribbon cable from the zero insert force connector with little force to remove the contact connecter from the motherboard.
  18. BLU Energy X Plus Screen Replacement: étape 18, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 18, image 2 de 2
  19. BLU Energy X Plus Screen Replacement: étape 19, image 1 de 1
  20. BLU Energy X Plus Screen Replacement: étape 20, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 20, image 2 de 2
    • Lift the small processor using a pair of tweezers.
    • Then, lift up the motherboard using your hand, lifting from the top of the motherboard.
  21. BLU Energy X Plus Screen Replacement: étape 21, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 21, image 2 de 2
    • Remove the zero insert force connector that's on the back side of the motherboard using a small blue plastic opening tool to lift up the black tab. Then pull the motherboard out of the phone.
    • Pull the motherboard vertically to pull the motherboard from the phone. It should still be attached by a wire on the left side.
  22. BLU Energy X Plus Screen Replacement: étape 22, image 1 de 3 BLU Energy X Plus Screen Replacement: étape 22, image 2 de 3 BLU Energy X Plus Screen Replacement: étape 22, image 3 de 3
    • Remove the connector wire from the motherboard using your finger nails. You will need to pull from the gold colored connecter, which is attached to the motherboard.
    • And, there's your motherboard.
  23. BLU Energy X Plus Screen Replacement, Speaker: étape 23, image 1 de 1
    • Remove the four silver screws using a J000 screwdriver bit .
    • Four silver screws, all 1.5mm in length.
  24. BLU Energy X Plus Screen Replacement: étape 24, image 1 de 1
    • There will be a fifth silver screw that is covered by a white sticker. Remove this screw using the J000 screw driver head.
    • One silver screw, 1.5mm in length.
  25. BLU Energy X Plus Screen Replacement: étape 25, image 1 de 2 BLU Energy X Plus Screen Replacement: étape 25, image 2 de 2
    • Lift the module where the speaker is located.
  26. BLU Energy X Plus Screen Replacement, Screen: étape 26, image 1 de 1
    • After removing all the components you will be left with the screen, as provided by BLU.
7 autres ont terminé cette réparation.
woodjake94
Membre depuis le 02/09/16
638 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 2-121, Cagle Spring 2016 Membre de l'équipe USF Tampa, Team 2-121, Cagle Spring 2016
USFT-CAGLE-S16S2G121
4 membres
5 tutoriels rédigés
4 commentaires de tutoriel
Hi!
Great disassemble guide!
I have a BLU Studio Energy 2, with the screen not working (blacked-out) but the touch screen is working.
I already purchased a new original LCD and Touch Screen set. Could You make a disassemble for this phone?
Thank You very much!
MSR - Réponse
This guide is incomplete and will not show you how to remove your screen. It will show you how to disassemble your phone and feel like a fool.
Brian Lamey - Réponse
where do i get the replacement screen from
Shaney Forde - Réponse
You missing main part how to get to the screen
Alphonso Phillip - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 5,507
