Aller au contenu principal
BLU Life XL Headphone Port Replacement
Ce dont vous avez besoin
  1. BLU Life XL Headphone Port Replacement, Volume Control Buttons: étape 1, image 1 de 3 BLU Life XL Headphone Port Replacement, Volume Control Buttons: étape 1, image 2 de 3 BLU Life XL Headphone Port Replacement, Volume Control Buttons: étape 1, image 3 de 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Headphone Port Replacement: étape 2, image 1 de 2 BLU Life XL Headphone Port Replacement: étape 2, image 2 de 2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Headphone Port Replacement: étape 3, image 1 de 2 BLU Life XL Headphone Port Replacement: étape 3, image 2 de 2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Headphone Port Replacement: étape 4, image 1 de 3 BLU Life XL Headphone Port Replacement: étape 4, image 2 de 3 BLU Life XL Headphone Port Replacement: étape 4, image 3 de 3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
  5. BLU Life XL Headphone Port Replacement, Motherboard: étape 5, image 1 de 2 BLU Life XL Headphone Port Replacement, Motherboard: étape 5, image 2 de 2
    • Remove the two 12x3mm screws using the Phillips #000 screwdriver.
    • Remove the ribbon cables.
  6. BLU Life XL Headphone Port Replacement: étape 6, image 1 de 3 BLU Life XL Headphone Port Replacement: étape 6, image 2 de 3 BLU Life XL Headphone Port Replacement: étape 6, image 3 de 3
    • The ribbon cables are attached by zero insertion force (ZIF) connectors. To disconnect the cable, flip up the small locking flap and pull the cable out.
  7. BLU Life XL Headphone Port Replacement: étape 7, image 1 de 3 BLU Life XL Headphone Port Replacement: étape 7, image 2 de 3 BLU Life XL Headphone Port Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
    • An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
  8. BLU Life XL Headphone Port Replacement: étape 8, image 1 de 3 BLU Life XL Headphone Port Replacement: étape 8, image 2 de 3 BLU Life XL Headphone Port Replacement: étape 8, image 3 de 3
    • The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward.
    • The motherboard is now free and can be replaced.
  9. BLU Life XL Headphone Port Replacement, Headphone Port: étape 9, image 1 de 2 BLU Life XL Headphone Port Replacement, Headphone Port: étape 9, image 2 de 2
    • There are 5 soldering points holding the headphone jack to the motherboard. Desolder the 5 solder points and remove the jack.
    • For help with soldering and desoldering, check out this guide.
Matthew Hook
Membre depuis le 03/25/19
439 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S1-G6, Hovde Fall 2019 Membre de l'équipe IUPUI, Team S1-G6, Hovde Fall 2019
IUPUI-HOVDE-F19S1G6
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 144
