Introduction
This guide is used to show how to replace the headphone port on the BLU Life XL. The headphone port may need replaced if your headphones work with other devices, but not in your BLU Life XL. Soldering experience is suggested.
Ce dont vous avez besoin
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
Remove the two 12x3mm screws using the Phillips #000 screwdriver.
Remove the ribbon cables.
There are 5 soldering points holding the headphone jack to the motherboard. Desolder the 5 solder points and remove the jack.
