Aller au contenu principal
BLU Life XL Speaker Replacement
Ce dont vous avez besoin
  1. BLU Life XL Speaker Replacement, Speaker: étape 1, image 1 de 3 BLU Life XL Speaker Replacement, Speaker: étape 1, image 2 de 3 BLU Life XL Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Speaker Replacement: étape 2, image 1 de 2 BLU Life XL Speaker Replacement: étape 2, image 2 de 2
    • Remove twelve 2.1mm Phillips #000 screws from the rear plate.
  3. BLU Life XL Speaker Replacement: étape 3, image 1 de 2 BLU Life XL Speaker Replacement: étape 3, image 2 de 2
    • Use an opening tool to separate the rear plate from the phone.
    • Firmly press the opening tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • If the opening tool is not working, try using your fingernails on the side of the phone. Once a small area of the rear plate is released, continue to use the opening tool.
    • Run the opening tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Speaker Replacement: étape 4, image 1 de 3 BLU Life XL Speaker Replacement: étape 4, image 2 de 3 BLU Life XL Speaker Replacement: étape 4, image 3 de 3
    • Gently flip the tan cable lock back to release the ribbon cable from the lower PCB Board.
    • Using a spudger, gently pull the ribbon cable from its socket.
    • Remove the 3mm screw from the PCB using a Phillips #000 screwdriver.
  5. BLU Life XL Speaker Replacement: étape 5, image 1 de 3 BLU Life XL Speaker Replacement: étape 5, image 2 de 3 BLU Life XL Speaker Replacement: étape 5, image 3 de 3
    • Locate the speaker and connected haptic motor on the lower PCB of the phone.
    • Using an opening tool, lightly pry around all edges of the PCB until it releases from the adhesive backing.
    • Use the same process as above to remove the Haptic motor. It has the black and red wire connected to it and the PCB.
Ligne d'arrivée
James Whitlow
Membre depuis le 02/14/18
342 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G5, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S2-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S2G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 302
