Introduction
Use this guide in order to successfully remove and replace the rear-facing camera on your BLU Studio 5.0 II phone.
Ce dont vous avez besoin
Locate the four 3mm screws on each side of the back panel.
Use a Phillips #00 screwdriver to remove the eight screws.
Outil utilisé dans cette étape :Tweezers$4.99
Locate the camera, which is centered on the upper part of the motherboard.
Use tweezers to lift the camera slowly.
Carefully pull the camera out of the motherboard.
Presque terminé !
