Aller au contenu principal
BLU Studio 5.0 II Volume Button Replacement
Ce dont vous avez besoin
  1. BLU Studio 5.0 II Volume Button Replacement, Battery: étape 1, image 1 de 1
    • Turn off your phone before disassembling the device.
    • Locate the small opening on the bottom corner of the back case.
  2. BLU Studio 5.0 II Volume Button Replacement: étape 2, image 1 de 2 BLU Studio 5.0 II Volume Button Replacement: étape 2, image 2 de 2
    • Use your finger to open the back case by slowly pulling it on the open slot.
    • Once the case is lifted on the corner, slide your finger along the edge of the phone to remove the rest of the case.
  3. BLU Studio 5.0 II Volume Button Replacement: étape 3, image 1 de 3 BLU Studio 5.0 II Volume Button Replacement: étape 3, image 2 de 3 BLU Studio 5.0 II Volume Button Replacement: étape 3, image 3 de 3
    • Locate the opening slot at the bottom of the battery.
    • Use your finger to lift the battery and remove it from the case.
  4. BLU Studio 5.0 II Volume Button Replacement, Back Case: étape 4, image 1 de 1
    • Locate the four 3mm screws on each side of the back panel.
    • Use a Phillips #00 screwdriver to remove the eight screws.
  5. BLU Studio 5.0 II Volume Button Replacement: étape 5, image 1 de 3 BLU Studio 5.0 II Volume Button Replacement: étape 5, image 2 de 3 BLU Studio 5.0 II Volume Button Replacement: étape 5, image 3 de 3
    • Carefully use a spudger to start opening the back case by inserting it between the black and blue lines on the side of the phone.
    • With the help of your fingers, continue to remove the back case by sliding it through the opening.
  6. BLU Studio 5.0 II Volume Button Replacement, Volume Button: étape 6, image 1 de 2 BLU Studio 5.0 II Volume Button Replacement, Volume Button: étape 6, image 2 de 2
    • Locate the volume button on the right side of the phone after removing back case.
    • Using a spudger carefully wedge between button and phone and carefully pry away from the phone.
    • Once removed the yellow buttons will be visible.
2 autres ont terminé cette réparation.
Zack Miliziano
Membre depuis le 02/09/16
146 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 7-5, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 7-5, Cheng Spring 2016
USFT-CHENG-S16S7G5
3 membres
7 tutoriels rédigés
0Commentaires sur le guide
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 17
Total : 253
