Aller au contenu principal
BLU Studio 5.0 S II Motherboard Replacement
Ce dont vous avez besoin
  1. BLU Studio 5.0 S II Motherboard Replacement, Remove back cover: étape 1, image 1 de 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Motherboard Replacement, Remove battery: étape 2, image 1 de 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Motherboard Replacement, Motherboard: étape 3, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement, Motherboard: étape 3, image 2 de 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Motherboard Replacement: étape 4, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 4, image 2 de 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Motherboard Replacement: étape 5, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 5, image 2 de 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Motherboard Replacement: étape 6, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 6, image 2 de 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Motherboard Replacement: étape 7, image 1 de 3 BLU Studio 5.0 S II Motherboard Replacement: étape 7, image 2 de 3 BLU Studio 5.0 S II Motherboard Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Motherboard Replacement: étape 8, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 8, image 2 de 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Motherboard Replacement: étape 9, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 9, image 2 de 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Motherboard Replacement: étape 10, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 10, image 2 de 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Motherboard Replacement: étape 11, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 11, image 2 de 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Motherboard Replacement: étape 12, image 1 de 2 BLU Studio 5.0 S II Motherboard Replacement: étape 12, image 2 de 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Motherboard Replacement: étape 13, image 1 de 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
To reassemble your device, follow these instructions in reverse order with the new motherboard.
Aaron Isaacs
Membre depuis le 03/01/17
107 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G3, Harley Spring 2017 Membre de l'équipe IUPUI, Team S2-G3, Harley Spring 2017
IUPUI-HARLEY-S17S2G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 478
