Introduction
This guide shows the steps to fix a BLU Studio G smartphone that is having connectivity problems found to be caused by a faulty antenna. The antenna is integrated into the motherboard, so a full motherboard replacement will be needed. If you are having problems with your connection to data or spotty reception, a motherboard replacement may refresh your broken phone.
Ce dont vous avez besoin
Étape 1 Motherboard Prerequisite
Attention : les étapes 1 à 8 sont issues d'un tutoriel marqué comme en cours.
To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Locate the two connector clamps on the motherboard.
Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
The antennae will be soldered directly to the motherboard which will be replaced.
