Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Over time, batteries lose their ability to hold a charge. If your BLU Studio G is losing charge quickly or won’t hold a charge at all, use this guide to replace its old battery with a fresh one.
Pièces
Aucune pièce spécifiée.
  1. To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down. Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device. Set back cover aside.
    • To remove the back cover, locate the safety indented notch on the bottom left corner as the screen is facing down.
    • Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
    • Set back cover aside.
  2. Locate the notch at the bottom of the battery for safe removal. Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Locate the notch at the bottom of the battery for safe removal.
    • Carefully lift battery from the notch making sure not to puncture the battery rubber casting.
    • Set battery aside and insert new one .
Christian Perez
Membre depuis le 11/04/2017
476 Réputation
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 99
