Introduction
To replace most components for the BLU Studio G, the motherboard will likely need to be replaced. Tools needed are a spudger (something small and sharp) and a screwdriver. When repairing any part of the device, it would be wise to have grounding strap.
Ce dont vous avez besoin
Étape 1 Motherboard Prerequisite
Attention : les étapes 1 à 8 sont issues d'un tutoriel marqué comme étant en cours.
To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Locate the two connector clamps on the motherboard.
Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
The headphone jack is located on the top right when face down, and is soldered onto the motherboard.
For assistance Identifying and re-soldering click the link for a video guide.
