Aller au contenu principal
BLU Tank II Front Panel Replacement
Ce dont vous avez besoin
  1. BLU Tank II Front Panel Replacement, Back Panel: étape 1, image 1 de 2 BLU Tank II Front Panel Replacement, Back Panel: étape 1, image 2 de 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Front Panel Replacement, Battery: étape 2, image 1 de 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Front Panel Replacement, Front Panel: étape 3, image 1 de 2 BLU Tank II Front Panel Replacement, Front Panel: étape 3, image 2 de 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Front Panel Replacement: étape 4, image 1 de 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
David Kelchner
Membre depuis le 03/08/17
632 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S6-G2, Isaacson Spring 2017 Membre de l'équipe UMass Dartmouth, Team S6-G2, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 237
