Aller au contenu principal
Replacing the Battery on a BLU Vivo 5
Ce dont vous avez besoin
  1. Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: étape 1, image 1 de 2 Replacing the Battery on a BLU Vivo 5, Remove bottom screws.: étape 1, image 2 de 2
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Replacing the Battery on a BLU Vivo 5, Remove the top cover.: étape 2, image 1 de 3 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: étape 2, image 2 de 3 Replacing the Battery on a BLU Vivo 5, Remove the top cover.: étape 2, image 3 de 3
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: étape 3, image 1 de 3 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: étape 3, image 2 de 3 Replacing the Battery on a BLU Vivo 5, Remove bottom cover.: étape 3, image 3 de 3
    • To remove the bottom cover, pull it upward.
  4. Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: étape 4, image 1 de 3 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: étape 4, image 2 de 3 Replacing the Battery on a BLU Vivo 5, Releasing the back cover.: étape 4, image 3 de 3
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. Replacing the Battery on a BLU Vivo 5, Removing the battery.: étape 5, image 1 de 3 Replacing the Battery on a BLU Vivo 5, Removing the battery.: étape 5, image 2 de 3 Replacing the Battery on a BLU Vivo 5, Removing the battery.: étape 5, image 3 de 3
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
es en
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
Eneider Colina
Membre depuis le 09/20/13
2 362 Réputation
9 tutoriels rédigés
Équipe
Comunidad para traductores de español Membre de l'équipe Comunidad para traductores de español
Community
23 membres
211 tutoriels rédigés
2 commentaires
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
V'Ger_iTech - Réponse
This guide is NOT for BLU Vivo 5. It's probably for the mini version. The BLU vivo 5 doesn't have screws at bottom...
Alaziz Hussain - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 26
Total : 3,931
