Aller au contenu principal
BLU Vivo One Plus Microphone Replacement
Ce dont vous avez besoin
  1. BLU Vivo One Plus Microphone Replacement, Battery: étape 1, image 1 de 3 BLU Vivo One Plus Microphone Replacement, Battery: étape 1, image 2 de 3 BLU Vivo One Plus Microphone Replacement, Battery: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    SIM Card Eject Tool
    $2.99
    J'achète
  2. BLU Vivo One Plus Microphone Replacement: étape 2, image 1 de 3 BLU Vivo One Plus Microphone Replacement: étape 2, image 2 de 3 BLU Vivo One Plus Microphone Replacement: étape 2, image 3 de 3
    iFixit Opening Tool
    $1.99
    J'achète
    • Use the plastic opening tool and run it under the entire seam that separates the screen and the plastic back of the phone.
    • Lodge the plastic opening tool under the back cover and use it to pry the two parts apart slowly.
    • This step will take a decent amount of force and it may seem as though the device will fracture, but you must keep pulling until the back releases.
  3. BLU Vivo One Plus Microphone Replacement: étape 3, image 1 de 2 BLU Vivo One Plus Microphone Replacement: étape 3, image 2 de 2
    Phillips #000 Screwdriver
    $5.49
    J'achète
    • Using a Phillips 000 screwdriver, remove the 14 1.5 mm screws that attach the plastic protection cover to the phone.
    • Removing the screws will cause a silver metal bracket by the top left corner of the battery to fall off. Keep track of it for later.
  4. BLU Vivo One Plus Microphone Replacement: étape 4, image 1 de 2 BLU Vivo One Plus Microphone Replacement: étape 4, image 2 de 2
    Spudger
    $3.99
    J'achète
    • After removing the screws, the bottom plastic cover will need to be removed to expose the rest of the phone’s interior.
    • The plastic cover should come off easily using your fingers, but you may need the spudger or an opening pick to remove it.
    • Remove the cover by its sides to ensure the removal is as easy as possible.
  5. BLU Vivo One Plus Microphone Replacement: étape 5, image 1 de 2 BLU Vivo One Plus Microphone Replacement: étape 5, image 2 de 2
    iFixit Opening Picks (Set of 6)
    J'achète
    • Remove the two blue strips of tape on the lower portion of the battery.
    • After removing the blue strips of tape gently begin wedging the plastic picks underneath the battery and locating the adhesive tape strips.
    • Utilize the picks in a fashion that both pries the battery upward and scrapes the adhesive either loose from the battery or phone body. Be careful not to bend or damage the battery and it should eventually come free from the housing.
  6. BLU Vivo One Plus Microphone Replacement: étape 6, image 1 de 2 BLU Vivo One Plus Microphone Replacement: étape 6, image 2 de 2
  7. BLU Vivo One Plus Microphone Replacement, Microphone: étape 7, image 1 de 2 BLU Vivo One Plus Microphone Replacement, Microphone: étape 7, image 2 de 2
    J'achète
    • Using either an opening pick or a pair of needle nosed tweezers, gently pry and lift the microphone away from the sub frame.
    • It has an adhesive coating applied to the back of it so there may be significant resistance.
  8. BLU Vivo One Plus Microphone Replacement: étape 8, image 1 de 2 BLU Vivo One Plus Microphone Replacement: étape 8, image 2 de 2
    • Once removed from the sub frame the microphone can be desoldered and the replacement part can be used. Click here to see how to solder.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 182
