Aller au contenu principal
BLU Vivo One Plus Speaker Replacement
Ce dont vous avez besoin
  1. BLU Vivo One Plus Speaker Replacement, Battery: étape 1, image 1 de 3 BLU Vivo One Plus Speaker Replacement, Battery: étape 1, image 2 de 3 BLU Vivo One Plus Speaker Replacement, Battery: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    SIM Card Eject Tool
    $2.99
  2. BLU Vivo One Plus Speaker Replacement: étape 2, image 1 de 3 BLU Vivo One Plus Speaker Replacement: étape 2, image 2 de 3 BLU Vivo One Plus Speaker Replacement: étape 2, image 3 de 3
    iFixit Opening Tool
    $1.99
    • Use the plastic opening tool and run it under the entire seam that separates the screen and the plastic back of the phone.
    • Lodge the plastic opening tool under the back cover and use it to pry the two parts apart slowly.
    • This step will take a decent amount of force and it may seem as though the device will fracture, but you must keep pulling until the back releases.
  3. BLU Vivo One Plus Speaker Replacement: étape 3, image 1 de 2 BLU Vivo One Plus Speaker Replacement: étape 3, image 2 de 2
    Phillips #000 Screwdriver
    $5.49
    • Using a Phillips 000 screwdriver, remove the 14 1.5 mm screws that attach the plastic protection cover to the phone.
    • Removing the screws will cause a silver metal bracket by the top left corner of the battery to fall off. Keep track of it for later.
  4. BLU Vivo One Plus Speaker Replacement: étape 4, image 1 de 2 BLU Vivo One Plus Speaker Replacement: étape 4, image 2 de 2
    Spudger
    $3.99
    • After removing the screws, the bottom plastic cover will need to be removed to expose the rest of the phone’s interior.
    • The plastic cover should come off easily using your fingers, but you may need the spudger or an opening pick to remove it.
    • Remove the cover by its sides to ensure the removal is as easy as possible.
  5. BLU Vivo One Plus Speaker Replacement: étape 5, image 1 de 2 BLU Vivo One Plus Speaker Replacement: étape 5, image 2 de 2
    iFixit Opening Picks (Set of 6)
    • Remove the two blue strips of tape on the lower portion of the battery.
    • After removing the blue strips of tape gently begin wedging the plastic picks underneath the battery and locating the adhesive tape strips.
    • Utilize the picks in a fashion that both pries the battery upward and scrapes the adhesive either loose from the battery or phone body. Be careful not to bend or damage the battery and it should eventually come free from the housing.
  6. BLU Vivo One Plus Speaker Replacement: étape 6, image 1 de 2 BLU Vivo One Plus Speaker Replacement: étape 6, image 2 de 2
  7. BLU Vivo One Plus Speaker Replacement, Speaker: étape 7, image 1 de 2 BLU Vivo One Plus Speaker Replacement, Speaker: étape 7, image 2 de 2
    • Use the tweezers to remove metallic tape on the metal speaker housing.
    • Set tape aside so it can be reattached later.
  8. BLU Vivo One Plus Speaker Replacement: étape 8, image 1 de 3 BLU Vivo One Plus Speaker Replacement: étape 8, image 2 de 3 BLU Vivo One Plus Speaker Replacement: étape 8, image 3 de 3
    • Remove the rubber protective covering from the side of the speaker using the tweezers.
  9. BLU Vivo One Plus Speaker Replacement: étape 9, image 1 de 3 BLU Vivo One Plus Speaker Replacement: étape 9, image 2 de 3 BLU Vivo One Plus Speaker Replacement: étape 9, image 3 de 3
    • Use the tweezers to remove the metal speaker housing from the phone. Set aside for later.
    • Wedge the tweezers in bottom right hand corner of the speaker and pry it up to remove it from the adhesive.
  10. BLU Vivo One Plus Speaker Replacement: étape 10, image 1 de 1
    • De-solder the wires from the bottom sub-frame and the speaker. Use the link listed to safely de-solder the speaker.
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 13
Total : 314
