Aller au contenu principal
BLU WIN HD LTE Battery Replacement
Ce dont vous avez besoin
  1. BLU WIN HD LTE Battery Replacement, Back Case: étape 1, image 1 de 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: étape 2, image 1 de 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: étape 3, image 1 de 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: étape 4, image 1 de 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: étape 5, image 1 de 2 BLU WIN HD LTE Battery Replacement, Battery: étape 5, image 2 de 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Taelar Tritton-Bowman
Membre depuis le 09/21/18
249 Réputation
3 tutoriels rédigés
Équipe
2 commentaires
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Réponse
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
raybrooks - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 648
