Aller au contenu principal
BMW 2003-2010 5 Series Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. BMW 2003-2010 5 Series Tail Light Bulb Replacement, Tail light Bulb: étape 1, image 1 de 1
    • Open the trunk of the car to access the tail lights.
    • Remove the two 5 mm screws holding the panel cover in place.
  2. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 2, image 1 de 1
    • With a flathead screwdriver, turn the screws half a turn counterclockwise.
  3. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 3, image 1 de 1
    • With plyers, remove the screws.
  4. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 4, image 1 de 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 4, image 2 de 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 4, image 3 de 3
    • Pull up the trunk matt and remove it from the corner.
    • Pull up the panel by the tab.
    • The panel should lift right out.
  5. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 5, image 1 de 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 5, image 2 de 3 BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 5, image 3 de 3
    • You will see the light bulb holster.
    • Turn the dial in the middle of of the black plastic light bulb holster.
    • Pull the holster out of the trunk bay.
  6. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 6, image 1 de 1
    • Grab the light bulb at the base and twist counterclockwise.
    • DO NOT TWIST THE BULB BY THE GLASS.
  7. BMW 2003-2010 5 Series Tail Light Bulb Replacement: étape 7, image 1 de 1
    • Pull out the bulb and repeat the process in reverse order with the new bulb to reassemble.
To reassemble, follow these instructions in reverse order.
Christophe Chedid
Membre depuis le 03/22/21
169 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G5, Saloman Spring 2021 Membre de l'équipe UMass Dartmouth, Team S3-G5, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G5
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 23
30 derniers jours : 177
Total : 2,978
