Aller au contenu principal
BOSE SoundTouch 30 Power Supply Replacement
Ce dont vous avez besoin
  1. BOSE SoundTouch 30 Power Supply Replacement, Base Plate: étape 1, image 1 de 2 BOSE SoundTouch 30 Power Supply Replacement, Base Plate: étape 1, image 2 de 2
    • Remove the four 15.5 mm PH2 screws securing the base plate to the device.
  2. BOSE SoundTouch 30 Power Supply Replacement, Power Supply: étape 2, image 1 de 1
    • Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
  3. BOSE SoundTouch 30 Power Supply Replacement: étape 3, image 1 de 2 BOSE SoundTouch 30 Power Supply Replacement: étape 3, image 2 de 2
    • Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
    • There is a small ribbon cable that connects the display assembly to the body of the device. Make sure to disconnect the cable before pulling the grille all the way off or else the cable could snap.
  4. BOSE SoundTouch 30 Power Supply Replacement: étape 4, image 1 de 1
    • Remove all four 15.5 mm PH2 screws holding the power supply down.
    • The power supply is identified by a green board with a large metal covering.
  5. BOSE SoundTouch 30 Power Supply Replacement: étape 5, image 1 de 2 BOSE SoundTouch 30 Power Supply Replacement: étape 5, image 2 de 2
    • Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
    • Pick up the power supply and remove the fourth cable from the underside of the power supply.
    • Remove the power supply.
9 autres ont terminé cette réparation.
Brennen Irey
Membre depuis le 04/18/18
1 065 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S16-G2, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S16-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G2
4 membres
6 tutoriels rédigés
29 commentaires
where can we buy the [power supply unit, as i have messed mine by using 220v instead of 110v
Hitesh Gohill - Réponse
Hello. Do you want to exchange power supplies?
Contact me please!
Tomás Rosales -
Hi. My name Josley from Brazil.
I need you Power supply module for bose soundtouch 30.
You can help me?
Josley Oliveira -
Hola donde puedo comprar el modulo SoundTouch 30 Power Supply.
Muchas gracias.
Isidro -
I have the opposite problem. Bought the 110v instead of the 220v and now I have to use a step down transformer. Wanna exchange power supplies?
tomas@familiarosales.cl
Tomás Rosales - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 29
30 derniers jours : 145
Total : 10,283
