Aller au contenu principal
Babyliss Ionic SL hairdryer power switch Replacement
Ce dont vous avez besoin
    • remove two special head screws from device handle. Special tool required.
    • carefully separate the two plastic parts. You might have to pry them open on both sides of the top part.
    • mark all cables for later reference.
    • ATTENTION: there is a capacitator/condensator close by, better to remove it to prevent contact with the hot solder iron.
    • Desolder switch prior to removing from casing.
    • carefully push switch from inside out.
    • You might have to use a pair of pliers and some force to release the switch from plastic casing.
    • CTR-1215-y from XXX
    • 7.5A 125 V or 15A 250V
    • thanks to your labels you know which cable goes where.
    • push the two plastic parts together
    • tighten the screws.
    • Congratulations, you are done!
Ligne d'arrivée
JoeMoe
Membre depuis le 09/09/21
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 9
30 derniers jours : 28
Total : 996
