Aller au contenu principal
Back Panel
Ce dont vous avez besoin
  1. Back Panel, Back Panel: étape 1, image 1 de 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
  2. Back Panel: étape 2, image 1 de 3 Back Panel: étape 2, image 2 de 3 Back Panel: étape 2, image 3 de 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
  3. Back Panel: étape 3, image 1 de 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
Meredith Shaffer
Membre depuis le 09/25/17
222 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 11
Total : 501
