Aller au contenu principal
Basis Peak Battery Replacement
Ce dont vous avez besoin
  1. Basis Peak Battery Replacement, Frame: étape 1, image 1 de 1
    • Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
    • Maintain this orientation to follow the guide.
  2. Basis Peak Battery Replacement: étape 2, image 1 de 2 Basis Peak Battery Replacement: étape 2, image 2 de 2
    • Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
  3. Basis Peak Battery Replacement: étape 3, image 1 de 1
    • Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
  4. Basis Peak Battery Replacement: étape 4, image 1 de 1
    • Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
    • The clips have small lips that you can put the spudger under to get more leverage.
    • Using any of the metal to pry out the electronics may damage some of the wiring. It is crucial to only press on the plastic.
  5. Basis Peak Battery Replacement, Motherboard: étape 5, image 1 de 1
    • Remove the right side ribbon cable by pulling it off with your fingers.
  6. Basis Peak Battery Replacement: étape 6, image 1 de 1
    • Use the spudger tool to poke out the exposed motherboard section as seen in the photo.
    • As always be careful when disconnecting the cables or batteries.
  7. Basis Peak Battery Replacement: étape 7, image 1 de 1
    • Put a nylon spudger underneath the battery's press-fit connector and lift up to free the ribbon cable and motherboard.
  8. Basis Peak Battery Replacement, Battery: étape 8, image 1 de 1
    • Grip the battery with your fingers and remove it from the plastic.
Dominic Calcasola
Membre depuis le 03/26/17
101 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S4-G4, Julie Spring 2017 Membre de l'équipe UMass Dartmouth, Team S4-G4, Julie Spring 2017
UMASSD-JULIE-S17S4G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 393
