Aller au contenu principal
Introduction
This guide will provide step by step instructions on how to locate and open the battery compartment, then install the batteries.
Outils
Aucun outil spécifié.
  1. Locate the battery compartment on the bottom right of the camera.
    • Locate the battery compartment on the bottom right of the camera.
  2. While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open. If the door does not pop open, gently lift the door using your finger.
    • While holding the camera with the lens facing toward you, slide the lock button to the right and pull the battery door towards you. The battery door should pop open.
    • If the door does not pop open, gently lift the door using your finger.
  3. Batteries pour ordinateurs portables
    Une réparation facile pour un gain en puissance max.
    Acheter maintenant
    Acheter maintenant
  4. Remove the dead batteries.  The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out.  If this does not work, you can simply pull them out.
    • Remove the dead batteries. The easiest way to do this is by turning the camera right side up and gently tapping the lens side of the camera against your hand until they fall out. If this does not work, you can simply pull them out.
  5. Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Insert fresh AA batteries into the compartment as demonstrated in the picture to the left. The orientation of the batteries is important to ensure the camera works properly.
    • Close the battery door.
    • Remember to slide the switch back into the lock position.
Reassembly of the camera is the final step in the guide.
Richard
Membre depuis le 19/04/2012
3 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-43, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 membres
6 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 1,698
