Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Battery Disconnect
Conditions préalables uniquement
Il s'agit d'un tutoriel prérequis ! Il fait partie d'une autre procédure et n'est pas destiné à être utilisé seul.
Ce dont vous avez besoin
  1. Battery Disconnect, Prepare your laptop for disassembly: étape 1, image 1 de 2 Battery Disconnect, Prepare your laptop for disassembly: étape 1, image 2 de 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Battery Disconnect, Remove the micro SIM card tray: étape 2, image 1 de 3 Battery Disconnect, Remove the micro SIM card tray: étape 2, image 2 de 3 Battery Disconnect, Remove the micro SIM card tray: étape 2, image 3 de 3
    • A SIM eject tool or bit isn't long enough to eject the tray.
    • Insert a straightened paper clip into the micro SIM card tray hole on the right edge of the laptop.
    • Press the paper clip firmly into the hole to eject the tray.
    • Remove the tray.
    • When reinserting the tray, slide the arms of the tray into the rectangular metal slot.
  3. Battery Disconnect, Battery information: étape 3, image 1 de 2 Battery Disconnect, Battery information: étape 3, image 2 de 2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  4. Battery Disconnect, Release the left tab: étape 4, image 1 de 2 Battery Disconnect, Release the left tab: étape 4, image 2 de 2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  5. Battery Disconnect, Remove the battery: étape 5, image 1 de 3 Battery Disconnect, Remove the battery: étape 5, image 2 de 3 Battery Disconnect, Remove the battery: étape 5, image 3 de 3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
  6. Battery Disconnect, Unfasten the back cover: étape 6, image 1 de 2 Battery Disconnect, Unfasten the back cover: étape 6, image 2 de 2
    • Use a Phillips screwdriver to loosen the eight captive screws securing the back cover.
    • Don't try to completely remove the screws—they're secured to the back cover with delicate, plastic clips.
  7. Battery Disconnect, Insert an opening pick: étape 7, image 1 de 3 Battery Disconnect, Insert an opening pick: étape 7, image 2 de 3 Battery Disconnect, Insert an opening pick: étape 7, image 3 de 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the bottom right edge of the back cover and frame.
    • Pry up the back cover to release the bottom right clips.
    • Leave the pick inserted in the bottom right corner.
  8. Battery Disconnect, Release the bottom edge clips: étape 8, image 1 de 3 Battery Disconnect, Release the bottom edge clips: étape 8, image 2 de 3 Battery Disconnect, Release the bottom edge clips: étape 8, image 3 de 3
    • During the next two steps, position your pick downward at a 45-degree angle to help release the clips.
    • Slide the pick to the bottom left corner to release the bottom clips.
  9. Battery Disconnect, Release the left edge clips: étape 9, image 1 de 2 Battery Disconnect, Release the left edge clips: étape 9, image 2 de 2
    • Insert your pick in the bottom left corner and slide the pick to the first USB port to release the left clips.
  10. Battery Disconnect, Release the top corner clips: étape 10, image 1 de 3 Battery Disconnect, Release the top corner clips: étape 10, image 2 de 3 Battery Disconnect, Release the top corner clips: étape 10, image 3 de 3
    • Insert an opening tool between the top left corner of the back cover and frame.
    • Pry the back cover up to release the clips securing its top left corner.
    • Repeat the process on the top right corner.
  11. Battery Disconnect, Release the top edge clips: étape 11, image 1 de 3 Battery Disconnect, Release the top edge clips: étape 11, image 2 de 3 Battery Disconnect, Release the top edge clips: étape 11, image 3 de 3
    • Five clips secure the top edge of the back cover.
    • Insert an opening tool in the gap between the back cover and frame, next to one of the clips.
    • Push the opening tool into the gap until the clip releases.
  12. Battery Disconnect: étape 12, image 1 de 3 Battery Disconnect: étape 12, image 2 de 3 Battery Disconnect: étape 12, image 3 de 3
    • Push the opening tool between the back cover and frame at different points along the top edge to release the remaining clips.
  13. Battery Disconnect, Remove the back cover: étape 13, image 1 de 3 Battery Disconnect, Remove the back cover: étape 13, image 2 de 3 Battery Disconnect, Remove the back cover: étape 13, image 3 de 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  14. Battery Disconnect, Disconnect the internal battery: étape 14, image 1 de 3 Battery Disconnect, Disconnect the internal battery: étape 14, image 2 de 3 Battery Disconnect, Disconnect the internal battery: étape 14, image 3 de 3
Spencer Day
Membre depuis le 09/14/22
160 273 Réputation
1 045 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
23 994 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 34
