Aller au contenu principal
Bear 1000 Power Entry Module Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Bear 1000 Power Entry Module Replacement, Air and O2 Blender: étape 1, image 1 de 1
    • Remove the ribbon cable at the connection on the oxygen blender control board.
  2. Bear 1000 Power Entry Module Replacement: étape 2, image 1 de 1
    • Mark the plastic hoses attached to the oxygen blender (so you can put them back on the same way) and then remove.
  3. Bear 1000 Power Entry Module Replacement: étape 3, image 1 de 1
    • The air/oxygen blender has two screws close to the control board. Remove them and remove the unit.
  4. Bear 1000 Power Entry Module Replacement, Air and O2 Inlet Manifold: étape 4, image 1 de 1
    • Remove the pneumatic and electrical connections labeled.
    • Remove the water trap bowls on the rear of the unit.
  5. Bear 1000 Power Entry Module Replacement: étape 6, image 1 de 1
    • Remove the four screws and remove the manifold.
    • Remove the two screws holding the power supply to the manifold.
    • Mark or label the 6 faston connections as to position and remove
    • Mark or label the two wires going to the power switch and remove at the power switch end
    • Using an allen wrench, remove the power cord retaining bracket.
  6. Bear 1000 Power Entry Module Replacement: étape 11, image 1 de 1
    • Using an allen wrench, remove the mounting screwa and nuts from the Power Entry Module.
    • After removing the heat shrink tubing, unsolder the two lower wires from the Power Entry Module, noting locations.
    • Solder the wires to the replacement module, covering the joints with heat shrink tubing.
    • Transfer the voltage selector drum from the original module to the replacement and reinstall.
Eli Ferman
Membre depuis le 04/08/20
607 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S7-G12, Paton Fall 2020 Membre de l'équipe Cal Poly, Team S7-G12, Paton Fall 2020
CPSU-PATON-F20S7G12
2 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 94
