Introduction
In this guide, you will remove the cables and screws from the motherboard. You will also take the Bluetooth antenna out of the speaker.
Ce dont vous avez besoin
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
Hola amigos y amigas como estan me pueden ayudar como puedo conseguier la placa del beatspill esta q esta aki xf urgente soy de Ecuador ciudad manta
Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
After completing the guide for removing the case, remove the cables connecting the speakers.
Simply pull up on them without pulling on the wires themselves.
Quiero toda esa placa madre xf quiero conectarme con un vendedor si es aki en Ecuador mucho mejor cuanto cuesta mi numero mobil es 0967197831 xf conctacteme
Using both hands, gently lift the motherboard from the case.
You have successfully removed the motherboard.
Donde lo puedo comprar
Hola q vale esa placa del beatspill
Xf cuanto cuesta
14 autres ont terminé cette réparation.
5 commentaires
Disculpe la molestia quisiera saber el número de parte de los transistores Q2,Q3
I have a question regarding the contents of circuit.
which type of IC is used in the circuit which is hided by a marker. And if you have that ic than how can i contact you.
I need the Beats Pill XL Motherboard.. where i can buy
Bonjour impeccable bien expliqué
Ou puis-je trouvé cette carte
Merci beaucoup
0967197831 este es mi movil nesecito saber cuanto cuesta la placa de este beatspill xf ayudeme
