Aller au contenu principal
Beats Solo 2 Wire Replacement
Ce dont vous avez besoin
  1. Beats Solo 2 Wire Replacement, Core Wire: étape 1, image 1 de 1
    • Pull out the wire from the beats. The wire is a jack wire and requires nothing special to remove.
  2. Beats Solo 2 Wire Replacement: étape 2, image 1 de 2 Beats Solo 2 Wire Replacement: étape 2, image 2 de 2
    • Remove the ear cushions from the headset. The preferred method to do this is to use a screwdriver and pry the cushions off.
  3. Beats Solo 2 Wire Replacement: étape 3, image 1 de 3 Beats Solo 2 Wire Replacement: étape 3, image 2 de 3 Beats Solo 2 Wire Replacement: étape 3, image 3 de 3
    • Remove the second cushion until both cushions are removed.
  4. Beats Solo 2 Wire Replacement: étape 4, image 1 de 3 Beats Solo 2 Wire Replacement: étape 4, image 2 de 3 Beats Solo 2 Wire Replacement: étape 4, image 3 de 3
    • Remove the screws from both ear bases.
  5. Beats Solo 2 Wire Replacement: étape 5, image 1 de 2 Beats Solo 2 Wire Replacement: étape 5, image 2 de 2
    • Once the screws are removed, pop off the inner speakers. Do this for both sides
  6. Beats Solo 2 Wire Replacement: étape 6, image 1 de 3 Beats Solo 2 Wire Replacement: étape 6, image 2 de 3 Beats Solo 2 Wire Replacement: étape 6, image 3 de 3
    • After you have removed the second internal speaker, you can begin the process of removing the wire. BE CAREFUL with this step, make sure you don't pull off the circuit board.
  7. Beats Solo 2 Wire Replacement: étape 7, image 1 de 3 Beats Solo 2 Wire Replacement: étape 7, image 2 de 3 Beats Solo 2 Wire Replacement: étape 7, image 3 de 3
    • Now we are going to remove the circuit board holder. Take off the white cover to get access to the screw. Then remove the screw and circuit board holder.
  8. Beats Solo 2 Wire Replacement: étape 8, image 1 de 3 Beats Solo 2 Wire Replacement: étape 8, image 2 de 3 Beats Solo 2 Wire Replacement: étape 8, image 3 de 3
    • slowly pry away cover
8 autres ont terminé cette réparation.
Darien Jewel
Membre depuis le 11/28/16
221 Réputation
1 tutoriel rédigé
Équipe
Coast Union High School, Team 1-4, Hartzell Fall 2016 Membre de l'équipe Coast Union High School, Team 1-4, Hartzell Fall 2016
CUHS-HARTZELL-F16S1G4
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 37
Total : 5,798
