Aller au contenu principal
Beats Solo 3 Headband Replacement
Ce dont vous avez besoin
  1. Beats Solo 3 Headband Replacement, Headband: étape 1, image 1 de 3 Beats Solo 3 Headband Replacement, Headband: étape 1, image 2 de 3 Beats Solo 3 Headband Replacement, Headband: étape 1, image 3 de 3
    • Carefully partially remove the headband cushion cover. Be careful not to rip the two headband eyelets just above the screws on each end of the headband.
  2. Beats Solo 3 Headband Replacement: étape 2, image 1 de 2 Beats Solo 3 Headband Replacement: étape 2, image 2 de 2
    • With the main part of the cover off, pull the head band cover up and out of the metal headband ends, exposing the screws underneath.
  3. Beats Solo 3 Headband Replacement: étape 3, image 1 de 3 Beats Solo 3 Headband Replacement: étape 3, image 2 de 3 Beats Solo 3 Headband Replacement: étape 3, image 3 de 3
    • Unscrew all four 1.4 mm screws on the right and left ends on the underside of the headband using a T5 Torx screwdriver.
  4. Beats Solo 3 Headband Replacement: étape 4, image 1 de 1
    • Pull the metal headband end out from the headband slightly, and disconnect the rubber band from the hook.
  5. Beats Solo 3 Headband Replacement: étape 5, image 1 de 2 Beats Solo 3 Headband Replacement: étape 5, image 2 de 2
    • Remove the inner headband by gently prying the edges and corners.
  6. Beats Solo 3 Headband Replacement: étape 6, image 1 de 1
    • Carefully peel up the glued wire in the headband.
  7. Beats Solo 3 Headband Replacement: étape 7, image 1 de 1
    • Pull the headband out of the slots gently.
  8. Beats Solo 3 Headband Replacement: étape 8, image 1 de 1
    • Put the new headband into the slots carefully.
4 autres ont terminé cette réparation.
Joseph Konadu
Membre depuis le 03/24/21
211 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G13, Riel Spring 2021 Membre de l'équipe UMass Dartmouth, Team S1-G13, Riel Spring 2021
UMASSD-RIEL-S21S1G13
1 membre
2 tutoriels rédigés
2 commentaires
help when i was putting on the new headband the snap on middle parts fell out and i cant put them back in (the metal connection parts)
koro - Réponse
same it happen to me as well
Bardo -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 58
30 derniers jours : 200
Total : 11,385
