Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Removing the ear cushion is an important first step to accessing the speaker housing. Unless you are only replacing the headband, You MUST remove the ear cushions to access the other components.
  1. Pinch the ear cushion between your thumb and forefinger. Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily. Carefully pull the cushion directly away from the earpiece.
    • Pinch the ear cushion between your thumb and forefinger.
    • Be very careful when pulling off the ear cushion, as the material holding the cushion onto the plastic ring can rip easily.
    • Carefully pull the cushion directly away from the earpiece.
    • The cushion will have a thin piece of foam inside of it that may fall out upon removal. Make sure to save this for reassembly.
    • Repeat for the other ear cushion.
  2. Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring. Congratulations, you now have access to the rest of the speaker! For reassembly, the black ring cannot snap back into the speaker the way it was disassembled.  It must first go inside the black lip of the ear   cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
    • Congratulations, you now have access to the rest of the speaker!
    • For reassembly, the black ring cannot snap back into the speaker the way it was disassembled. It must first go inside the black lip of the ear cushion. The black lip is located on the back side of the ear cushion. Please refer to the last two pictures on this step.
    • The black lip is located on the back side of the ear cushion.
Ligne d'arrivée
13 autre(s) ont terminé cette réparation.
Anand Mangal
Membre depuis le 15/04/2014
959 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 9-18, Regan Spring 2014 Membre de l'équipe Cal Poly, Team 9-18, Regan Spring 2014
CPSU-REGAN-S14S9G18
4 membres
8 tutoriels rédigés
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
IGNACIO GREIFFENSTEIN - Réponse
What if I break the black ring where do I get a replacement
Chris h - Réponse
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Jade ijeh - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 101
Total : 58,653
