Aller au contenu principal
Beats Studio3 Wireless Speaker Replacement
Ce dont vous avez besoin
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: étape 1, image 1 de 2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: étape 1, image 2 de 2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: étape 2, image 1 de 3 Beats Studio3 Wireless Speaker Replacement: étape 2, image 2 de 3 Beats Studio3 Wireless Speaker Replacement: étape 2, image 3 de 3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: étape 3, image 1 de 2 Beats Studio3 Wireless Speaker Replacement, Speaker: étape 3, image 2 de 2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: étape 4, image 1 de 3 Beats Studio3 Wireless Speaker Replacement: étape 4, image 2 de 3 Beats Studio3 Wireless Speaker Replacement: étape 4, image 3 de 3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: étape 5, image 1 de 3 Beats Studio3 Wireless Speaker Replacement: étape 5, image 2 de 3 Beats Studio3 Wireless Speaker Replacement: étape 5, image 3 de 3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
Nayeli watts
Membre depuis le 03/16/23
474 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 Membre de l'équipe UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023
UMASSD-RYCKEBUSCH-S23S7G4
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 16
30 derniers jours : 80
Total : 852
