Aller au contenu principal
Beboncool Wireless Switch Pro Controller Buttons Replacement
Ce dont vous avez besoin
  1. Beboncool Wireless Switch Pro Controller Buttons Replacement, Motherboard: étape 1, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
  2. Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 2, image 1 de 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 2, image 2 de 2
    • Gently separate the top and bottom halves of the controller.
  3. Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 3, image 1 de 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 3, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 5 mm screws holding the joystick motherboard in place.
  4. Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 4, image 1 de 1
    • Carefully move the bumper buttons out of the way.
  5. Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 5, image 1 de 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 5, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the 5 mm screw holding the motherboard in place.
    • Remove the motherboard.
  6. Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: étape 6, image 1 de 2 Beboncool Wireless Switch Pro Controller Buttons Replacement, Buttons: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    • To remove the alphabetic buttons, remove the translucent silicone cover.
    • Use tweezers or your fingers to remove the buttons.
    • Pushing a button from below will elevate them enough to easily grab them.
  7. Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 7, image 1 de 2 Beboncool Wireless Switch Pro Controller Buttons Replacement: étape 7, image 2 de 2
    • To remove the directional buttons, first remove the translucent silicone cover. Then, use tweezers or your fingers to remove the button pad.
    • As with the alphabetic buttons, push on the buttons from below, then grab them.
Tayah Appel
Membre depuis le 03/27/23
529 Réputation
5 tutoriels rédigés
Équipe
Casper College, Team 1-3, Lareau Spring 2023 Membre de l'équipe Casper College, Team 1-3, Lareau Spring 2023
CASC-LAREAU-S23S1G3
3 membres
5 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 195
