Introduction
Use this guide to replace the outer casing of the lower handle of your Bed Head Wave Artist Deep Waver. It will show you how to split the lower handle housing and separate the two halves from each other and the rest of the device.
Ce dont vous avez besoin
Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
Remove two 10 mm Phillips #01 screws from the lower handle housing.
Remove one 10 mm Phillips #02 screw from the lower handle housing.
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
