Aller au contenu principal
Bed Head Wave Artist Deep Waver Power Cord Replacement
Ce dont vous avez besoin
  1. Bed Head Wave Artist Deep Waver Power Cord Replacement, Lower Handle Housing: étape 1, image 1 de 2 Bed Head Wave Artist Deep Waver Power Cord Replacement, Lower Handle Housing: étape 1, image 2 de 2
    • Before disassembling your Deep Waver, be sure to unplug the device to avoid electric shock, and make sure the heating elements of the device are cool to avoid burns.
    • Unlock the handle of your Deep Waver to gain access to the screws you need to remove.
    • Remove two 10 mm Phillips #01 screws from the lower handle housing.
    • Remove one 10 mm Phillips #02 screw from the lower handle housing.
  2. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 2, image 1 de 1
    • Pry the black screw cover off the side of the lower handle housing using a fine-point spudger or pick. This side will have the model number and other product information embossed on it.
  3. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 3, image 1 de 1
    • Remove one 10 mm Phillips 1 screw from the handle joint.
  4. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 4, image 1 de 1
    • Pry the black screw cover off the other side of the lower handle housing. This side will have the power switch located on it.
  5. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 5, image 1 de 1
    • Cut along the length of the black housing retainer with a rotary tool to split and remove the retainer.
  6. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 6, image 1 de 1
    • Split the lower handle housing apart using a plastic opening tool.
    • Begin splitting the housing at one end rather than the center to avoid cracking the casing.
  7. Bed Head Wave Artist Deep Waver Power Cord Replacement, Power Cord: étape 7, image 1 de 1
    • Pull upward on the power cord connector to remove it from the lower handle housing.
  8. Bed Head Wave Artist Deep Waver Power Cord Replacement: étape 8, image 1 de 1
    • Gently pull the power cord out of the power lead connector.
To reassemble your device, follow these instructions in reverse order. Once each half of the housing have been put back together, install a new Housing Retainer to replace the one you cut off.
Grant Peters
Membre depuis le 11/06/17
401 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S6-G3, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S6-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G3
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 10
Total : 517
