Introduction
The audio amplification PCB is the PCB which has the task of amplifying the B212D speaker's input signals.
Ce dont vous avez besoin
Remove the 8 Phillips screws from the back of the speaker.
There are two silver, 6 mm-long machine screws with two 1/8" inner-diameter washers on the exterior of the metal electronics box; remove these first using a #2 philips screwdriver.
There are five of the same type of machine screw (silver, 6 mm-long) remaining around the metal electronics box's exterior; remove these as well.
Remove the 4, 7/32" long machine screws with a #2 phillips head screwdriver.
Remove the 2 indicated flat head machine screws indicated using a #2 phillips head screwdriver.
Remove the audio amplification PCB from the metal electronics box.
If you haven't already, remove the heat sink from the IC's, being careful not to get any of the ceramic thermal paste on your skin, as it is difficult to remove, even with soap.
Hi I need replacement parts for the Behringer b212. Where can I buy them?
shannonleggettemusic@gmail.com
Hi very good tuto but same question ... where i can buy the Audio Amplification PCB? lestyx@wanadoo.fr
5 autres ont terminé cette réparation.
6 commentaires
lol pareil je cherche la pcb
I need the panel where I buy it
Calde.dc@GMAIL.COM
Cho toi so do thiet bi nay k
Eurolive B212d back plate requirement
Ashok Ahlawat - Réponse
