Introduction
This guide will walk you through how to replace the front casing on the NetCam.
Ce dont vous avez besoin
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Use tweezers to gently pull out the white attachment from the port.
Use your fingers to pull out the white attachment from the tan port on the front of the board a little.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
