Aller au contenu principal
Bella 4-Slice Toaster Oven Glass Door Replacement
Ce dont vous avez besoin
  1. Bella 4-Slice Toaster Oven Glass Door Replacement, Outer Shell: étape 1, image 1 de 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 2, image 1 de 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 3, image 1 de 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 4, image 1 de 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 5, image 1 de 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 6, image 1 de 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 7, image 1 de 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 8, image 1 de 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: étape 9, image 1 de 2 Bella 4-Slice Toaster Oven Glass Door Replacement, Glass Door: étape 9, image 2 de 2
    • Unhook the black coil springs from back of the toaster on both sides of the device.
  10. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 10, image 1 de 1
    • Use the black spudger to gently depress the hinge prongs on the bottom of the door.
  11. Bella 4-Slice Toaster Oven Glass Door Replacement: étape 11, image 1 de 2 Bella 4-Slice Toaster Oven Glass Door Replacement: étape 11, image 2 de 2
    • Gently slide door away from the device, removing it from the device.
Pierce Hampton
Membre depuis le 01/31/19
561 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 12
Total : 882
