Aller au contenu principal
Bella 4-Slice Toaster Oven Heating Element Replacement
Ce dont vous avez besoin
  1. Bella 4-Slice Toaster Oven Heating Element Replacement, Outer Shell: étape 1, image 1 de 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 2, image 1 de 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 3, image 1 de 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 4, image 1 de 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 5, image 1 de 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 6, image 1 de 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 7, image 1 de 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 8, image 1 de 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Heating Element Replacement, Heating Element: étape 9, image 1 de 1
    • Remove the red wire from the heating element.
  10. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 10, image 1 de 1
    • Remove white wire from the opposite side of the heating element.
  11. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 11, image 1 de 1
    • Use a metal spudger to unfold the tabs of metal that hold heating element in place.
  12. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 12, image 1 de 3 Bella 4-Slice Toaster Oven Heating Element Replacement: étape 12, image 2 de 3 Bella 4-Slice Toaster Oven Heating Element Replacement: étape 12, image 3 de 3
    • Gently push the heating element from the side with the red wire to remove it from the toaster.
  13. Bella 4-Slice Toaster Oven Heating Element Replacement: étape 13, image 1 de 1
    • Repeat steps 1-4 for the second heating element.
Pierce Hampton
Membre depuis le 01/31/19
561 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 49
Total : 1,906
