Aller au contenu principal
Bella 4-Slice Toaster Oven Timer Replacement
Ce dont vous avez besoin
  1. Bella 4-Slice Toaster Oven Timer Replacement, Outer Shell: étape 1, image 1 de 1
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Timer Replacement: étape 2, image 1 de 1
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Timer Replacement: étape 3, image 1 de 1
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Timer Replacement: étape 4, image 1 de 1
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Timer Replacement: étape 5, image 1 de 1
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Timer Replacement: étape 6, image 1 de 1
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Timer Replacement: étape 7, image 1 de 1
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Timer Replacement: étape 8, image 1 de 1
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Timer Replacement, Timer: étape 9, image 1 de 1
    • Using a plastic spudger, gently pry the black plastic timing dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Timer Replacement: étape 10, image 1 de 2 Bella 4-Slice Toaster Oven Timer Replacement: étape 10, image 2 de 2
    • Remove two 5.91 mm #2 Phillips screws which secure the timer to the toaster.
  11. Bella 4-Slice Toaster Oven Timer Replacement: étape 11, image 1 de 3 Bella 4-Slice Toaster Oven Timer Replacement: étape 11, image 2 de 3 Bella 4-Slice Toaster Oven Timer Replacement: étape 11, image 3 de 3
    • Inside the device, unplug the red and black wires from the top of the timer.
  12. Bella 4-Slice Toaster Oven Timer Replacement: étape 12, image 1 de 1
    • Remove timer from device interior.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 10
Total : 608
