Introduction
Use this guide to replace the lightbulb inside of a Bella Pro 90246 12.6-qt. Digital Air Fryer Oven.
The lightbulb inside the air fryer is used to check the cooking status of your food. Without this working, you face the risk of cooking too long and burning your food. Following this guide will help you disassemble the air fryer to locate the light bulb, complete the replacement, and extend the use of your air fryer.
Before you start the lightbulb replacement, it is important to gather all the necessary tools listed in the “What you need” section of the guide. You will need to purchase a new Halogen GY6.35 light bulb that is an exact fit for the circuit. Before you begin disassembly, make sure your air fryer is unplugged, and then you're ready to begin.
Ce dont vous avez besoin
To reassemble your device follow this guide in reverse order starting with step 11.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
Can I please get a picture of the circuit board from both sides? I plugged this air fryer in 220 volts, which might've caused a couple resistors to go bad and I am trying to replace them, but I don't know the exact value of them
