Aller au contenu principal
Bella TXG-FS075A Heating Element Replacement
Ce dont vous avez besoin
  1. Bella TXG-FS075A Heating Element Replacement, Heating Element: étape 1, image 1 de 3 Bella TXG-FS075A Heating Element Replacement, Heating Element: étape 1, image 2 de 3 Bella TXG-FS075A Heating Element Replacement, Heating Element: étape 1, image 3 de 3
    • Use a spudger to pry off the metal top of the air fryer.
  2. Bella TXG-FS075A Heating Element Replacement: étape 2, image 1 de 2 Bella TXG-FS075A Heating Element Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to pry off the plastic frame.
  3. Bella TXG-FS075A Heating Element Replacement: étape 3, image 1 de 3 Bella TXG-FS075A Heating Element Replacement: étape 3, image 2 de 3 Bella TXG-FS075A Heating Element Replacement: étape 3, image 3 de 3
    • Remove the four 13 mm screws from the second plastic frame using a Phillips #2 screwdriver.
    • Pry off the black plastic frame.
  4. Bella TXG-FS075A Heating Element Replacement: étape 4, image 1 de 1
    • Remove the two 13 mm screws using a Phillips #2 screwdriver.
  5. Bella TXG-FS075A Heating Element Replacement: étape 5, image 1 de 3 Bella TXG-FS075A Heating Element Replacement: étape 5, image 2 de 3 Bella TXG-FS075A Heating Element Replacement: étape 5, image 3 de 3
    • Using a spudger, pry off the outer frame.
    • Pull up on the outer frame, exposing the inner wall of the fryer.
  6. Bella TXG-FS075A Heating Element Replacement: étape 6, image 1 de 2 Bella TXG-FS075A Heating Element Replacement: étape 6, image 2 de 2
    • Remove the 13 mm screw connecting to the heating element's bracket using a Phillips #2 screwdriver.
  7. Bella TXG-FS075A Heating Element Replacement: étape 7, image 1 de 2 Bella TXG-FS075A Heating Element Replacement: étape 7, image 2 de 2
    • Pull out the heating element.
Braeden Vlasak
Membre depuis le 10/02/23
531 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 29
Total : 129
