Aller au contenu principal
Bem Wireless HL2739B Speaker Battery Replacement
Ce dont vous avez besoin
  1. Bem Wireless HL2739B Speaker Battery Replacement, Speaker Battery: étape 1, image 1 de 1
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B Speaker Battery Replacement: étape 2, image 1 de 3 Bem Wireless HL2739B Speaker Battery Replacement: étape 2, image 2 de 3 Bem Wireless HL2739B Speaker Battery Replacement: étape 2, image 3 de 3
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B Speaker Battery Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B Speaker Battery Replacement: étape 4, image 1 de 1
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B Speaker Battery Replacement: étape 5, image 1 de 1
    • Using tweezers, pull the wires from the metal base connection.
3 autres ont terminé cette réparation.
John Donovan
Membre depuis le 02/28/17
137 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S2-G4, Nance Spring 2017 Membre de l'équipe USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 10
Total : 2,436
