Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This guide will show you how to remove the rough coil of the magneto. A bad rough coil can cause the aircraft engine to run poorly and shake.
Pièces
Aucune pièce spécifiée.
  1. Use a #2 Flathead screw driver to remove the five screws on the body of the magneto.
    • Use a #2 Flathead screw driver to remove the five screws on the body of the magneto.
  2. Locate the two screws, one on the left and one on the right, of the primary circuit.
    • Locate the two screws, one on the left and one on the right, of the primary circuit.
    • Remove the screws using a #2 Flathead screw driver.
  3. Remove the primary circuit and replace it.
    • Remove the primary circuit and replace it.
    • The super coil may seem as though it does not come out but it does, it can just be a little jammed.
2 autre(s) ont terminé cette réparation.
Kelsi English
Membre depuis le 26/09/2012
405 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-2, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 1-2, Propen Fall 2012
CPSU-PROPEN-F12S1G2
4 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 2,032
