Aller au contenu principal
Beyblade LR String Launcher Fix
Ce dont vous avez besoin
  1. Beyblade LR String Launcher Fix, Beyblade LR String Launcher Fix: étape 1, image 1 de 2 Beyblade LR String Launcher Fix, Beyblade LR String Launcher Fix: étape 1, image 2 de 2
    • Use a Phillips #00 screwdriver to remove five screws from the bottom of the launcher.
  2. Beyblade LR String Launcher Fix: étape 2, image 1 de 1
    • Use a spudger to pry the cover off exposing the gear that houses the string.
  3. Beyblade LR String Launcher Fix: étape 3, image 1 de 2 Beyblade LR String Launcher Fix: étape 3, image 2 de 2
    • Unravel the string from the gear.
    • Remove the gear that was housing the string.
  4. Beyblade LR String Launcher Fix: étape 4, image 1 de 2 Beyblade LR String Launcher Fix: étape 4, image 2 de 2
    • Use a flathead screwdriver to rotate the slot on the front of the gear counterclockwise 9-10 times.
  5. Beyblade LR String Launcher Fix: étape 5, image 1 de 2 Beyblade LR String Launcher Fix: étape 5, image 2 de 2
    • Keep the flathead screwdriver in the slot.
    • Place the gear back in the socket with the slot perpendicular.
    • Carefully remove the flathead screwdriver.
    • Push on the slot to recall the string.
  6. Beyblade LR String Launcher Fix: étape 6, image 1 de 3 Beyblade LR String Launcher Fix: étape 6, image 2 de 3 Beyblade LR String Launcher Fix: étape 6, image 3 de 3
    • Put the cover back on the string launcher.
    • Use a Phillips #00 screwdriver to replace the five screws that secure the cover.
To reassemble, follow these instructions in reverse order.
Thomas Wong
Membre depuis le 01/13/24
163 Réputation
1 tutoriel rédigé
Équipe
York University, Team 2-29, O'Regan Winter 2024 Membre de l'équipe York University, Team 2-29, O'Regan Winter 2024
YORK-O'REGAN-W24S2G29
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 43
Total : 114
