Aller au contenu principal
Beyerdynamic MMX100 Volume Controller Repair
Ce dont vous avez besoin
  1. Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: étape 1, image 1 de 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: étape 1, image 2 de 3 Beyerdynamic MMX100 Volume Controller Repair, Beyerdynamic MMX100 Volume Controller Repair: étape 1, image 3 de 3
    • Twist the left speaker cushion towards you, and pull off the headset.
  2. Beyerdynamic MMX100 Volume Controller Repair: étape 2, image 1 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 2, image 2 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 2, image 3 de 3
    • Using the 2.0mm Phillips-Head screwdriver, unscrew the two 0.6mm screws at the end of the left side headband.
  3. Beyerdynamic MMX100 Volume Controller Repair: étape 3, image 1 de 2 Beyerdynamic MMX100 Volume Controller Repair: étape 3, image 2 de 2
    • Hold open the top part of the headband. Slide out the left earphone.
  4. Beyerdynamic MMX100 Volume Controller Repair: étape 4, image 1 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 4, image 2 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 4, image 3 de 3
    • Using the 3.0mm Phillips-Head Screwdriver, unscrew the three 0.7 mm screws on the left speaker cover.
  5. Beyerdynamic MMX100 Volume Controller Repair: étape 5, image 1 de 2 Beyerdynamic MMX100 Volume Controller Repair: étape 5, image 2 de 2
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.5mm screws on the volume control component.
  6. Beyerdynamic MMX100 Volume Controller Repair: étape 6, image 1 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 6, image 2 de 3 Beyerdynamic MMX100 Volume Controller Repair: étape 6, image 3 de 3
    • Take out, and flip over, the volume control component.
  7. Beyerdynamic MMX100 Volume Controller Repair: étape 7, image 1 de 2 Beyerdynamic MMX100 Volume Controller Repair: étape 7, image 2 de 2
    • Using the 2.0mm Phillips-Head Screwdriver, unscrew the two 0.3mm screws on the board. Then, take off the volume wheel.
  8. Beyerdynamic MMX100 Volume Controller Repair: étape 8, image 1 de 2 Beyerdynamic MMX100 Volume Controller Repair: étape 8, image 2 de 2
    • Hazardous situation which, if not avoided, could result in minor or moderate injury.
    • Using a soldering iron, desolder the damaged wires and the prongs on either side of the board.
Anthony Grande
Membre depuis le 10/23/23
157 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-9, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 5-9, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G9
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 12
30 derniers jours : 50
Total : 333
