Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Bicycle Cassette Replacement
Ce dont vous avez besoin
  1. Bicycle Cassette Replacement, Bicycle Cassette: étape 1, image 1 de 2 Bicycle Cassette Replacement, Bicycle Cassette: étape 1, image 2 de 2
    • Place your wheel on a hard surface with the cassette on your right side.
    • Wrap the chain whip clockwise around the cassette.
  2. Bicycle Cassette Replacement: étape 2, image 1 de 3 Bicycle Cassette Replacement: étape 2, image 2 de 3 Bicycle Cassette Replacement: étape 2, image 3 de 3
    • Insert the cassette lockring tool into the center of the cassette with the lever arm between 7 and 9 o'clock.
    • Holding the chain whip in place with your left hand, apply counterclockwise force on the cassette tool's lever arm.
    • Continue turning the cassette tool until the tool spins freely.
  3. Bicycle Cassette Replacement: étape 3, image 1 de 3 Bicycle Cassette Replacement: étape 3, image 2 de 3 Bicycle Cassette Replacement: étape 3, image 3 de 3
    • Lay the wheel down on a flat surface with the cassette facing upwards.
    • Loosen the cassette lockring by turning it counterclockwise.
  4. Bicycle Cassette Replacement: étape 4, image 1 de 3 Bicycle Cassette Replacement: étape 4, image 2 de 3 Bicycle Cassette Replacement: étape 4, image 3 de 3
    • Remove the cassette lockring.
    • Using both hands, lift the cassette in one piece from the freehub body.
  5. Bicycle Cassette Replacement: étape 5, image 1 de 2 Bicycle Cassette Replacement: étape 5, image 2 de 2
    • Your cassette may require a spacer to work properly with your freehub. Consult your cassette user's manual to determine your spacer needs.
    • Remove the old freehub body spacer as needed.
  6. Bicycle Cassette Replacement: étape 6, image 1 de 3 Bicycle Cassette Replacement: étape 6, image 2 de 3 Bicycle Cassette Replacement: étape 6, image 3 de 3
    • Locate the small cutout on the bottom of the new cassette.
    • Locate the small ridge on the freehub body.
    • Slide the bottom piece of the new cassette on the freehub body by matching the small cutout with the small ridge.
  7. Bicycle Cassette Replacement: étape 7, image 1 de 3 Bicycle Cassette Replacement: étape 7, image 2 de 3 Bicycle Cassette Replacement: étape 7, image 3 de 3
    • Continue placing smaller cogs on the freehub body by matching the cutouts and ridges.
    • Insert spacers as specified by the cassette user's manual.
  8. Bicycle Cassette Replacement: étape 8, image 1 de 3 Bicycle Cassette Replacement: étape 8, image 2 de 3 Bicycle Cassette Replacement: étape 8, image 3 de 3
    • For the final two cogs, locate the small cutouts and place on top of the already placed cogs by aligning with the top of small ridge on the freehub body.
    • The top two cogs will not fully slide on to the freehub body and require more attention for aligned placement.
  9. Bicycle Cassette Replacement: étape 9, image 1 de 2 Bicycle Cassette Replacement: étape 9, image 2 de 2
    • Place the cassette lockring onto the top of the final cog.
    • Start threading the lockring clockwise into the freehub by hand.
  10. Bicycle Cassette Replacement: étape 10, image 1 de 3 Bicycle Cassette Replacement: étape 10, image 2 de 3 Bicycle Cassette Replacement: étape 10, image 3 de 3
    • Once the lockring is partially threaded in, insert the cassette lockring tool.
    • Tighten the cassette on the freehub body by turning the lockring tool clockwise.
    • The exact torque to tighten to varies by cassette manufacturer and model. Consult the cassette user's manual.
    • After finishing tightening, check the cassette for play by pulling up on the largest cog. If excess play is present and the cassette has been tightened to specifications, a spacer is likely missing.
Ligne d'arrivée
Lars Lundqvist
Membre depuis le 04/14/25
208 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-5, Morris Spring 2025 Membre de l'équipe UC Davis, Team 1-5, Morris Spring 2025
UCD-MORRIS-S25S1G5
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 33
30 derniers jours : 118
Total : 973
